Issues in Isometric drawing mode
Hi Everybody,
As you know there are two styles in drawing in Bricscad i.e. Standard and Isometric. I am working in Isometric style for creating isometric drawings by changing the style i.e
Snap -> Style -> Isometric , now when i am drawing in isomteric while changing the plane i.e. either Left/Right/Top the rubber banding does not change as the plane changes, which means if i have to draw the object by changing the plane i need to cancel the command and change the plane first then start drawing this is a time consuming task, and this works fine in AutoCAD so can you guys tell me some solution to this, do i have to set some system variable to get it right.
Thanks in advance
Sanjay.
I found Snap Iso too cumbersome to summon up altogether a long time ago.
I have a lisp called ROT.lsp (below) which loads with on_doc_load.lsp - (LOAD "ROT")
I just type 30, 60, 15, 0 etc (+CR) and the axes turn around. The default angle for text follows the axes around too - you can take or leave that part.
PASTE CODE HERE
(defun txtrot () (setvar "textangle" (getvar "snapang")))
(defun c:0 () (setvar "snapang" 0)(txtrot))
(defun c:10 () (setvar "snapang" (* PI (/ 10.0 180.0)))(txtrot))
(defun c:15 () (setvar "snapang" (* PI (/ 15.0 180.0)))(txtrot))
(defun c:30 () (setvar "snapang" (/ pi 6))(txtrot))
(defun c:45 () (setvar "snapang" (/ pi 4))(txtrot))
(defun c:60 () (setvar "snapang" (/ pi 3))(txtrot))
(defun c:75 () (setvar "snapang" (* pi (/ 75.0 180.0)))(txtrot))
(defun c:80 () (setvar "snapang" (* pi (/ 80.0 180.0)))(txtrot))
(defun c:90 () (setvar "snapang" (/ pi 2))(txtrot))0 -
Hi!
Same problem here ...but: if you scroll (mouse) 1 time up and 1 time down, you'll see the rubberband! Or PAN with the mouse ...
With LISP - no way ... not yet
0 -
Hi W, there are some posters here who frighten me with their familiarity with different programming methods.
I'm not the sharpest knife in the drawer, but I got a reasonable grasp of lisp with just a bit of reading before the internet came along.
It would perhaps be easier now with tools like google and I really feel CAD users are missing out on a lot by avoiding lisp.
The dawn of a new age came for me when I typed (+ 2 2) on the command line and it said 4.
0 -
@John: do you use your lisp in combination with Snap -> Style -> Isometric?
0 -
No Roy, I wrote it because Snap Iso was too slow to get at and I didn't find the triple axis much help.
I find it more handy to have other angles available and default text angle change with it.
I can use the same action - typing "30" or "15" for other operations in addition to isometric drawings.
It seems like I don't have to stop and think "what's next" so often.
Also from memory I might have had other lisps which did not behave properly using Snap Iso - one offsets lines at the snapangle, multiplying the true distance by 0.8 (the isometric forshortening distance I use). Saves calculating it.
0
