Eliminate border around attached image?
Is there any way to use an attached image in a drawing and not have a border around it in the print-out?
If I make the image's color RGB:255,255,255 there's no border but also no image.
If I put the image on Defpoints layer, the image itself doesn't print.
Color 255 looks white in the Select Color palette, but it displays and prints grey.
Have you tried "ImageFrame" and set it to off?
Thanks! That's just what I needed.
Howdy, Stranger!
