Clearing the Active SelectionSet
in Other
What does the Clear method on the ActiveSelectionSet do.
After I have the user select some items on the drawing, I do some processing.
Then I want to clear the selected (and highlighted items) so I do the following (myActiveDoc is a reference to the Active Document)
myActiveDoc.ActiveSelectionSet.Clear()
After doing this, the property myActiveDoc.ActiveSelectionSet.Count is not zero as I would expect.
Another question, are selected items necessarily highlighted. Is there a way of unhighlighting all items?
Thank you , Mark Bosley
0
Hi Mark,
This code seems to work as advertised, you may be needing to cache a copy of the ActiveSet to variable.
public static class Commands
[CommandMethod("doit")]
public static void test01()
var app = Application.AcadApplication as AcadApplication;
var doc = app.ActiveDocument;
try
AcadSelectionSet aset = doc.ActiveSelectionSet;
doc.Utility.Prompt(String.Format("\n{0}", aset.Count));
foreach (AcadEntity e in aset)
e.Highlight(true);
//foreach (AcadEntity e in aset)
// e.Highlight(false);
aset.Clear();
aset.Delete();
catch (System.Exception ex)
doc.Utility.Prompt(String.Format("\n{0}", ex.Message));
}0
