Bricscad v10.6.4 Fedora 12 x86_64 - Any Debug Feature Avail?
This starts, displays the splash and seg faults with no information.
I am guessing a library problem, but
Q: Is there any way to start in debug/verbose mode?
I did try on an i386 platform and was impressed to have a native Cad app that can handle autocad dwg drawings, yet without being able to put on my personal machine there is no point me buying a licence yet.
James
  • Even in my Fedora 13 (32-bit - i686) I have problems starting Bricscad. Opens, showing the splash screen but then stops. This happens with nvidia-drivers akmod. With Nouveau starts, but do not see anything because of missing support for my card. I have this problem on three previous versions, including on the F12.
  • Yes I do seem to have some Nvidia libs installed, but this is a ATI machine
    [jamesarbrown@jblaptop ~]$ rpm -qa |grep nvidia
    nvidia-graphics190.53-libs-190.53-120.fc12.i686
    [jamesarbrown@jblaptop ~]$ lsmod
    Module Size Used by
    fuse 57189 2
    nls_utf8 1389 8
    cifs 232841 8
    rfcomm 66832 4
    sco 16714 2
    bridge 48306 0
    stp 1935 1 bridge
    llc 4739 2 bridge,stp
    bnep 15431 2
    l2cap 45755 16 rfcomm,bnep
    vboxnetadp 4755 0
    vboxnetflt 10983 0
    vboxdrv 1738598 2 vboxnetadp,vboxnetflt
    sunrpc 193817 1
    ipv6 279495 34
    cpufreq_ondemand 8793 2
    powernow_k8 14706 0
    freq_table 3947 2 cpufreq_ondemand,powernow_k8
    microcode 19061 0
    dm_multipath 14558 0
    uinput 7228 0
    snd_hda_codec_analog 73668 1
    snd_usb_audio 85725 3
    lib80211_crypt_tkip 8030 0
    wl 1960236 0
    snd_usb_lib 16556 1 snd_usb_audio
    uvcvideo 54603 0
    snd_hda_intel 23952 2
    snd_rawmidi 20374 1 snd_usb_lib
    snd_hda_codec 71956 2 snd_hda_codec_analog,snd_hda_intel
    snd_seq 52773 0
    btusb 15380 2
    bluetooth 89475 9 rfcomm,sco,bnep,l2cap,btusb
    videodev 33864 1 uvcvideo
    snd_pcm 78247 3 snd_usb_audio,snd_hda_intel,snd_hda_codec
    snd_seq_device 6151 2 snd_rawmidi,snd_seq
    v4l1_compat 12922 2 uvcvideo,videodev
    snd_timer 19840 2 snd_seq,snd_pcm
    snd_hwdep 6446 2 snd_usb_audio,snd_hda_codec
    hp_wmi 4984 0
    v4l2_compat_ioctl32 9579 1 videodev
    pegasus 22724 0
    rfkill 16966 4 bluetooth,hp_wmi
    snd 62376 21 snd_hda_codec_analog,snd_usb_audio,snd_usb_lib,snd_hda_intel,snd_rawmidi,snd_hda_codec,snd_seq,snd_pcm,snd_seq_device,snd_timer,snd_hwdep
    edac_core 39597 0
    sisusbvga 47555 0
    mct_u232 9072 0
    mii 4270 1 pegasus
    snd_page_alloc 7389 2 snd_hda_intel,snd_pcm
    sky2 42018 0
    soundcore 6271 1 snd
    usbserial 33647 1 mct_u232
    lib80211 5071 2 lib80211_crypt_tkip,wl
    shpchp 29656 0
    i2c_piix4 12139 0
    edac_mce_amd 7746 0
    wmi 6872 1 hp_wmi
    hp_accel 12040 0
    lis3lv02d 6745 1 hp_accel
    input_polldev 2744 1 lis3lv02d
    joydev 9528 0
    serio_raw 4642 0
    video 20118 0
    output 2213 1 video
    radeon 584645 2
    ttm 49268 1 radeon
    drm_kms_helper 24584 1 radeon
    drm 171002 4 radeon,ttm,drm_kms_helper
    i2c_algo_bit 5005 1 radeon
    i2c_core 26876 6 videodev,i2c_piix4,radeon,drm_kms_helper,drm,i2c_algo_bit
  • On the machine that mounts an ATI Radeon HD 4350, I have the usual problems of trails left on the screen, but you can work with Bricscad.
    I have "only" those big problems with NVIDIA I can not and do not know how to solve
  • So I should expect problems as I'm already poised to download v10.4.6 (I do believe you meant v10.4.6-1 and not v10.6.4).  I had v10.4.4 and it ran reasonably well on my Fedora 12 (i686) OS. Well, not so for the RPM though ... was using the TGZ.  The RPM had SELinux issues.  I have now upgraded to Fedora 13 and its x86_64.  I tried to run same v10.4.4 and I got:
    /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
    yum provides ld-linux.so.2
    yielded:
    glibc for i686 (glibc for x86_64 didn't have it).
    I was hoping to get a better result with v10.4.6-1, now I'm not so sure anymore.  Does this mean there is no support for Linux 64bit Architecture especially Fedora?
