Bricscad (Linux) Beta 10.4.9
2»
  • Thanks Elmer. I had the same issue....back up and running again.
  • I found the solution to run the V10.4.9-1 .deb package in Ubuntu 10.04 64-bit!
    I should have payed attention to what Risto Saarikko said. What is needed is the "ia32-libs" 32-bit compatibility package for 64-bit architecture. It was already installed in my Ubuntu 9.10 64-bit partition, maybe that's why it used to work. Look for it in Synaptic, or in the terminal type
    sudo apt-get install ia32-libs (or replace apt-get with aptitude if that's what you use, I've read you shouldn't mix both commands)
    The only thing, I get an error message at start: " Cannot set locale to 'en_US' " (my system locale is fr_CA). But I close it and it does not prevent Bricscad from running.
    Very happy to finally be able to run Bricscad again.
  • <!-- @page { margin: 2cm } P { margin-bottom: 0.21cm } -->
    Good morning at all,
    The product steel grow very good, my compliments.
    I have a problem with the selection of the object, every time I select a line or a block or a part of drawing for copy move or other command the selected part disappear, and so began very hard continue in the work. Is that a bug or have I to change any settings?
    BR
    Stefano
  • @Sander
    Thanks for the license key.  I'm trusting that all of the output functionality will be included in the commercial release.
    I've found most everything is working for my own production processes with the latest beta.
    But there's one big problem - namely the inability to generate plots with plot styles.  The plot output dialog recognizes my .ctb files, but I can't get output that reflects it.  I also can't get large format output - for my use PDF format.  I've tried a handful of PDF printers, including the CUPS-PDF printer.  But I get color output, with A4 sheet size.
    I'm currently having to boot into windows and use AutoCAD for generating output.
    If I've missed something, and that functionality is fully in place, but I'm not correctly configured, I'd love to learn how to make it work.
    Thanks,  Brad
  • @ Stefano: I have not this problem, for me works fine when select objects.
  • Hello,
    for a absolute LINUX-newbie like me it was possible to install Bricscad on UBUNTU 10.04. It looks great, complimets to the Brisys team!
    But one question. When I call the add/edit object data function the window is poor. Is it a problem of beta state?
    BR - Peter
  • Note for developers...
    If i have a dwg file with 2 or 3 raster image attached, the graphic area is very slow. In win, is a little bit faster.
    Thk
    David
    Today I had many crashes Bricscad. So I launched the application from the terminal and this is what I got when the block.
    [giacomob@Pc-Linux ~]$ bricscad
    (bricscad:5468): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
    *** glibc detected *** /opt/bricsys/bricscad/v10/bricscad: free(): invalid next size (fast): 0xad26a200 ***
    ======= Backtrace: =========
    /lib/libc.so.6(+0xab8fe1)[0x74acfe1]
    /opt/bricsys/bricscad/v10/libDD_Alloc.so(odrxFree+0x1d)[0x196a1d]
    /opt/bricsys/bricscad/v10/libDD_Alloc.so(_ZdaPv+0x21)[0x196ab1]
    /opt/bricsys/bricscad/v10/libDD_Ge.so(_ZN8OdGeTess7Contour9normalizeEd+0x866)[0x1998176]
    /opt/bricsys/bricscad/v10/libDD_Ge.so(_ZN8OdGeTess7Contour13breakToConvexEj+0xb7)[0x1998a67]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier12shellFaceOutElPKlPK12OdGeVector3d+0x6f0)[0x4bb8580]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier18generateShellFacesElPKlPK12OdGiEdgeDataPK12OdGiFaceData+0x194)[0x4bb9f34]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0xc3)[0x4bb7303]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiSelectProcImpl9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0x77)[0x4c33857]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN13OdGiXformImpl9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0x427)[0x4c42407]
    /opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN14OdTrueTypeFont12outCharacterEPvP20OdGiConveyorGeometryRK16OdTextProperties+0x27c)[0x6dceec]
    /opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN16OdTrueTypeFontFT13drawCharacterEwR11OdGePoint2dP20OdGiConveyorGeometryRK16OdTextProperties+0x90)[0x6df330]
    /opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN18OdGiDefaultContext8drawTextEP20OdGiConveyorGeometryRK11OdGePoint3dRK12OdGeVector3dS7_PKwlbPK13OdGiTextStylePS6_+0xa9c)[0x6be59c]
    /opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa16ExGiContextForDb8drawTextEP20OdGiConveyorGeometryRK11OdGePoint3dRK12OdGeVector3dS8_PKwlbPK13OdGiTextStylePS7_+0xfd)[0xcf62ad]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier8textProcERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStylePS4_+0x1a7)[0x4bb7847]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN13OdGiXformImpl8textProcERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStylePS4_+0x145)[0x4c40065]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4textERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStyle+0x158)[0x4b914c8]
    /opt/bricsys/bricscad/v10/libodapp.so(_ZN23OdGsOpenGLVectorizeView4textERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStyle+0x8c)[0xd3292c]
    /opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK13OdDbMTextImpl13drawFragmentsER12OdGiGeometryP14OdGiCommonDrawP7OdArrayI19OdMTextFragmentData18OdObjectsAllocatorIS5_EE+0x32c)[0x2096efc]
    /opt/bricsys/bricscad/v10/libDD_Db.so(_ZN13OdDbMTextImpl9drawMTextEP13OdGiWorldDrawb+0x1f7)[0x20aedf7]
    /opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK9OdDbMText9worldDrawEP13OdGiWorldDraw+0xb0)[0x20b10d0]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer6doDrawEmPK12OdGiDrawable+0x1e)[0x4b8e5fe]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN21OdGsBaseVectorizeView6doDrawEmPK12OdGiDrawable+0xb2)[0x8475c12]
    /opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa17BaseVectorizeView6doDrawEmPK12OdGiDrawable+0x5b)[0xcccbcb]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4drawEPK12OdGiDrawable+0x160)[0x4b8f550]
    /opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK20OdDbBlockTableRecord9worldDrawEP13OdGiWorldDraw+0x25d)[0x23ae7fd]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4drawEPK12OdGiDrawable+0x3d5)[0x4b8f7c5]
    /opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK13OdDbDimension9worldDrawEP13OdGiWorldDraw+0x144)[0x1fcca84]
    /opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4drawEPK12OdGiDrawable+0x340)[0x4b8f730]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN14OdGsEntityNode6selectER21OdGsBaseVectorizeView+0x18f)[0x84a730f]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdSiSelectVisitor5visitEP10OdSiEntitybPK9OdSiShape+0x117)[0x84c19d7]
    /opt/bricsys/bricscad/v10/libDD_SpatialIndex.so(_ZNK4OdSi9IndexImpl5queryERK9OdSiShapeR11OdSiVisitor+0xa6)[0xa0da06]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdGsReferenceImpl6selectER21OdGsBaseVectorizeViewP11OdSiVisitorPK9OdSiShapebN8OdGsView13SelectionModeE+0x101)[0x8499601]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN23OdGsSharedRefDefinition6selectER21OdGsBaseVectorizeViewP11OdSiVisitorPK9OdSiShapebN8OdGsView13SelectionModeE+0x38)[0x8498a68]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN23OdGsSharedReferenceImpl6selectER21OdGsBaseVectorizeViewP11OdSiVisitorPK9OdSiShapebN8OdGsView13SelectionModeE+0xed)[0x8499fed]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN22OdGsBlockReferenceNode6selectER21OdGsBaseVectorizeViewP11OdSiVisitorPK9OdSiShapeN8OdGsView13SelectionModeE+0x286)[0x84954d6]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdSiSelectVisitor5visitEP10OdSiEntitybPK9OdSiShape+0x64)[0x84c1924]
    /opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN21OdGsBaseVectorizeView6selectEPK11OdGePoint2diP20OdGsSelectionReactorN8OdGsView13SelectionModeE+0x1065)[0x84bff35]
    /opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa10CDwgViewer6selectEPK11OdGePoint2diP16OdDbSelectionSetN8OdGsView13SelectionModeEPNS_25SelectionMarkersContainerEbPK19OdDbSelectionFilterPNS_9CSubentSSE+0x1ce)[0xdbc20e]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca9CSsGetImp14getSinglePointER10OdSmartPtrI16OdDbSelectionSetERK11OdGePoint3dPN2oa9CSubentSSE+0x1b6)[0x3b0606]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca11ssgetByModeERNS_5CaDocENS_10ESSgetModeER10OdSmartPtrI16OdDbSelectionSetEPK19OdDbSelectionFilterPK11OdGePoint3diiPN2oa9CSubentSSE+0x110)[0x3b5fc0]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor12processPointERK11OdGePoint3d+0x279)[0x298f49]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor18processNextCmdItemEi+0x112)[0x29a682]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor11processIdleEv+0x8b)[0x29a7db]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor4mainEv+0x28)[0x29a8c8]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor5startEv+0x63)[0x29aa03]
    /opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor16mainWorkFlowProcEPv+0x25)[0x29ab85]
    /opt/bricsys/bricscad/v10/libpth.so.20(+0x7d39)[0xa1ad39]
    /lib/libc.so.6(makecontext+0x4b)[0x747a44b]
    /lib/libglib-2.0.so.0(g_thread_use_default_impl+0x0)[0x2f96618]
    ======= Memory map: ========
    00110000-00153000 r-xp 00000000 fd:00 531310     /opt/bricsys/bricscad/v10/libflyoversnap.so
    00153000-00155000 r--p 00043000 fd:00 531310     /opt/bricsys/bricscad/v10/libflyoversnap.so
    00155000-00156000 rw-p 00045000 fd:00 531310     /opt/bricsys/bricscad/v10/libflyoversnap.so
    00156000-00160000 r-xp 00000000 fd:00 531411     /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
    00160000-00161000 ---p 0000a000 fd:00 531411     /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
    00161000-00162000 r--p 0000a000 fd:00 531411     /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
    00162000-00163000 rw-p 0000b000 fd:00 531411     /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
    00163000-0016c000 r-xp 00000000 fd:00 531399     /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
    0016c000-0016d000 r--p 00008000 fd:00 531399     /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
    0016d000-0016e000 rw-p 00009000 fd:00 531399     /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
    0016e000-00195000 r-xp 00000000 fd:00 22592      /usr/lib/libpng12.so.0.44.0
    00195000-00196000 rw-p 00027000 fd:00 22592      /usr/lib/libpng12.so.0.44.0
    00196000-00197000 r-xp 00000000 fd:00 529988     /opt/bricsys/bricscad/v10/libDD_Alloc.so
    00197000-00198000 r--p 00001000 fd:00 529988     /opt/bricsys/bricscad/v10/libDD_Alloc.so
    00198000-00199000 rw-p 00002000 fd:00 529988     /opt/bricsys/bricscad/v10/libDD_Alloc.so
    00199000-0019c000 r-xp 00000000 fd:00 7672       /lib/libdl-2.12.so
    0019c000-0019d000 r--p 00002000 fd:00 7672       /lib/libdl-2.12.so
    0019d000-0019e000 rw-p 00003000 fd:00 7672       /lib/libdl-2.12.so
    0019e000-00463000 r-xp 00000000 fd:00 530825     /opt/bricsys/bricscad/v10/libcadapp.so
    00463000-0046d000 r--p 002c5000 fd:00 530825     /opt/bricsys/bricscad/v10/libcadapp.so
    0046d000-00481000 rw-p 002cf000 fd:00 530825     /opt/bricsys/bricscad/v10/libcadapp.so
    00481000-00485000 rw-p 00000000 00:00 0
    00485000-00497000 r-xp 00000000 fd:00 21926      /lib/libz.so.1.2.3
    00497000-00498000 rw-p 00011000 fd:00 21926      /lib/libz.so.1.2.3
    00498000-0049b000 r-xp 00000000 fd:00 29395      /lib/libgmodule-2.0.so.0.2400.1
    0049b000-0049c000 rw-p 00002000 fd:00 29395      /lib/libgmodule-2.0.so.0.2400.1
    0049c000-004a0000 r-xp 00000000 fd:00 27479      /lib/libgthread-2.0.so.0.2400.1
    004a0000-004a1000 rw-p 00003000 fd:00 27479      /lib/libgthread-2.0.so.0.2400.1
    004a3000-004ac000 r-xp 00000000 fd:00 531369     /opt/bricsys/bricscad/v10/libgeometry.so
    004ac000-004ad000 r--p 00008000 fd:00 531369     /opt/bricsys/bricscad/v10/libgeometry.so
    004ad000-004ae000 rw-p 00009000 fd:00 531369     /opt/bricsys/bricscad/v10/libgeometry.so
    004ae000-004c0000 r-xp 00000000 fd:00 531430     /opt/bricsys/bricscad/v10/libzlib.so
    004c0000-004c1000 r--p 00011000 fd:00 531430     /opt/bricsys/bricscad/v10/libzlib.so
    004c1000-004c2000 rw-p 00012000 fd:00 531430     /opt/bricsys/bricscad/v10/libzlib.so
    004c2000-004c3000 r-xp 00000000 00:00 0          [vdso]
    004c3000-00576000 r-xp 00000000 fd:00 531402     /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
    00576000-0057e000 r--p 000b3000 fd:00 531402     /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
    0057e000-0057f000 rw-p 000bb000 fd:00 531402     /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
    0057f000-00581000 rw-p 00000000 00:00 0
    00581000-005a7000 r-xp 00000000 fd:00 18888      /lib/libexpat.so.1.5.2
    005a7000-005a9000 rw-p 00025000 fd:00 18888      /lib/libexpat.so.1.5.2
    005a9000-005cc000 r-xp 00000000 fd:00 529989     /opt/bricsys/bricscad/v10/libDD_Br.so
    005cc000-005ce000 r--p 00022000 fd:00 529989     /opt/bricsys/bricscad/v10/libDD_Br.so
    005ce000-005cf000 rw-p 00024000 fd:00 529989     /opt/bricsys/bricscad/v10/libDD_Br.so
    005cf000-005d6000 r-xp 00000000 fd:00 11347      /lib/librt-2.12.so
    005d6000-005d7000 r--p 00006000 fd:00 11347      /lib/librt-2.12.so
    005d7000-005d8000 rw-p 00007000 fd:00 11347      /lib/librt-2.12.so
    005d8000-005da000 r-xp 00000000 fd:00 29809      /usr/lib/libXinerama.so.1.0.0
    005da000-005db000 rw-p 00001000 fd:00 29809      /usr/lib/libXinerama.so.1.0.0
    005db000-005dd000 r-xp 00000000 fd:00 64233      /lib/libcom_err.so.2.1
    005dd000-005de000 rw-p 00002000 fd:00 64233      /lib/libcom_err.so.2.1
    005de000-005e0000 r-xp 00000000 fd:00 32184      /usr/lib/libXdamage.so.1.1.0
    005e0000-005e1000 rw-p 00001000 fd:00 32184      /usr/lib/libXdamage.so.1.1.0
    005e1000-00690000 r-xp 00000000 fd:00 531391     /opt/bricsys/bricscad/v10/libutils.so
    00690000-00691000 r--p 000af000 fd:00 531391     /opt/bricsys/bricscad/v10/libutils.so
    00691000-00694000 rw-p 000b0000 fd:00 531391     /opt/bricsys/bricscad/v10/libutils.so
    00694000-00696000 rw-p 00000000 00:00 0
    00696000-006ec000 r-xp 00000000 fd:00 530037     /opt/bricsys/bricscad/v10/libDD_DbRoot.so
    006ec000-006ee000 r--p 00056000 fd:00 530037     /opt/bricsys/bricscad/v10/libDD_DbRoot.so
    006ee000-006f2000 rw-p 00058000 fd:00 530037     /opt/bricsys/bricscad/v10/libDD_DbRoot.so
    006f2000-006f9000 r-xp 00000000 fd:00 61761      /usr/lib/libSM.so.6.0.0
    006f9000-006fa000 rw-p 00006000 fd:00 61761      /usr/lib/libSM.so.6.0.0
    006fa000-006fd000 r-xp 00000000 fd:00 61843      /lib/libgpg-error.so.0.5.0
    006fd000-006fe000 rw-p 00002000 fd:00 61843      /lib/libgpg-error.so.0.5.0
    006fe000-00770000 r-xp 00000000 fd:00 531307     /opt/bricsys/bricscad/v10/libdcl.so
    00770000-00773000 r--p 00071000 fd:00 531307     /opt/bricsys/bricscad/v10/libdcl.so
    00773000-00774000 rw-p 00074000 fd:00 531307     /opt/bricsys/bricscad/v10/libdcl.so
    00774000-00795000 rw-p 00000000 00:00 0
    00795000-00929000 r-xp 00000000 fd:00 530826     /opt/bricsys/bricscad/v10/libcmdapi.so
    00929000-00930000 r--p 00193000 fd:00 530826     /opt/bricsys/bricscad/v10/libcmdapi.so
    00930000-00933000 rw-p 0019a000 fd:00 530826     /opt/bricsys/bricscad/v10/libcmdapi.so
    00933000-00934000 rw-p 00000000 00:00 0
    00934000-009bd000 r-xp 00000000 fd:00 531426     /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
    009bd000-009c0000 r--p 00089000 fd:00 531426     /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
    009c0000-009c1000 rw-p 0008c000 fd:00 531426     /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
    009c1000-009c2000 rw-p 00000000 00:00 0
    009c2000-009d5000 r-xp 00000000 fd:00 529985     /opt/bricsys/bricscad/v10/libBrxBase.soAbortito (core dumped)
    What does this mean?
  • The trial period on the current Beta version says it expires in a couple of days and there is no for-sale version in the E-store.
    It would be nice to know a day or two in advance  what is intended.
    Where to from here?
  • Hi
    Beta is expired. What do we do now?
    Regartds,
    Cristobal
  • If you need an extension of your Linux trial key, contact us to request one.
  • @ Chamberland, have the same problem, get an error message at start: " Cannot set locale to 'en_US' " (my system locale is es_UY), but after close the message, all works fine. Don't know how to quit this message.
    @ Hake,  "But there's one big problem - namely the inability to generate plots with plot styles.  The plot output dialog recognizes my .ctb files, but I can't get output that reflects it.  I also can't get large format output - for my use PDF format.  I've tried a handful of PDF printers, including the CUPS-PDF printer.  But I get color output, with A4 sheet size."
    Have the same problem, can't print with A3 or A2 format. I think that plot still needs work.
