Printing Line Weights
I am finding that Bricscad prints lines heavier than ACAD LT & Progecad (for the same settings). Is there a quick fix?
Welcome!
It looks like you're new here. Sign in or register to get started.
  • It looks like I am the only one having this problem
  • I haven't had any program to compare with for a long time, but my prints seem to be what I expect for any given line thickness.
    I only use colours to dictate printed line thicknesses, not actual line weights or polylines as a rule.
    I was using a Dotted linetype to make polylines of varying thicknesses to represent flexible duct of different diameters, but the result (thickness of the dots, which elongated into ribs) varied over a few Bcad revisions and I stopped doing it.
    There was some manipulation within the program to change the printed outcome in similar instances, but I never heard of similar for straight out lines.
  • I also only use colours to dictate printed line thickness. All entities are drawn at the default line thickness of 0 mm. Layer line weight is set to 0 mm.
    Horizontal line weight prints out thinner than vertical lines
  • I did a print earlier with a piece of a PDF I had produced, just now I did one of the same area of that dwg direct to the same printer and there is no difference.
    It happens to have a 0.5mm line very close to a .25 hidden line in both hor and vert - the ink in the plane the print head travels spreads slightly so they merge in that direction, but I can't generally discern a difference between directions. I use .18 pen thickness as thinnest and can't imagine a thinner pen actually working in the "good old days" by hand.
    I seem to remember at one time encountering pen thicknesses confused  between inches and mm's in the print settings, but the result was pretty obvious.
    Other than that, could it be a plot style table you think you have set but is not actually being used by Bcad to print? (just guessing at possibilities)
Welcome!
