mouse settings
hello, I'm looking for the mouse settings.
When using the rightklcbutton the last command was always repeated.
since one of the last udates? I can't find the settings. rightbutton is now set as Delete.
Thanks,
Sander
Are you using the most recent version, V10.4.18 ?
Right-click action is defined by the system variable SHORTCUTMENU, wich you can edit in the settings dialog. It can be set to display a shortcut menu, if not it should repeat the last command. If it does not do so in V10.4.18, please submit a support request with a scenario to reproduce the issue so we can solve it.
0 -
It happened to me too, for the first time, this week, that right-click was delete instead of repeat.
I exited BC, restarted it and all was well again (V10.4.18).
0 -
Does it happen always ? Does it also happen when you hit enter ? We can't reproduce it here, if you can give us more info to reproduce it, it would help us a lot, we 'd be glad to fix it asap.
0 -
It was the first time it happend to me, and it took a few moments until I realised what's going on.
All I remember is, the command sequence was "delete" and then "champfer", I used the
right mouse button for repeating "champfer" but "delete" came up, I didn't try "enter". Unfortunately
I can't remember if I tried it on another drawing to see if it's related to a drawing. Now, I will observe more carefully
when it happens again.
0 -
Using V10.4.18.
Didn't try exiting drawing when it happend.
started up this morning in the same drawing and by right-click mouse i got the full menu. Pressing "enter" after a command repeats the last comamand as should be.
guess is was a "hanging command:" or something like that.
I'm sorry ( or glad :-) ) i can't reproduce it at this time.
will keep it in mind an pay more attention if/when it happends next time.
Thanks for the replys
Sander
0 -
I have BricsCAD Pro 10.5.5 build 19729 and I have the similar ptoblems with the mouse setting. My right-click button brings up the Zoom command regardless what was the previous command. The problem I having is that, I can not change this behavior and I always have to go back to the side icons to execute the command. Would not repeat. Anybody can suggest a solution to the above problem I would really apreciate .
0 -
I had similar unexpected responses once, in perhaps the original V10. It happened right before Bcad failed to start at all.
I don't know why the response changed, but it turned out that a Command in my startup lisp which had always worked in the past, suddenly caused havoc.
Can I suggest disabling any customised on_doc or on_start lisps and menus to see if it still happens.
0 -
Hello,
The probblem with this perticular problem is that it's not reproducable every time.
It sometimes comes up. I don't use BC every day.
It happend also in version 10.5.5 and older.
Last time it hapend i had no time to traceback my steps. maybe next time (hope not ;-))
Sander
0 -
Hello John Gaunt & Sander de Geus,
I hope the senario of "Bcad failed to start" won't happen. I started to play around with the "Mouseshortcut" variable where you can change the settings from 0 to 16. Setting it to 16 (in my case anyway) the right mouse button repeats the last command executed. Will see how long is last as in the past I had various problems as the system without any worning changes some of the settings worked before. I am running Bcad on Windows 7 Professional 64 bit system with 6GB system memory and 1TB HDD. So, the room available for the program is not a problem. Thanks for your attention to my problem - aakdraft.
0 -
Hello Sander de Geus,
Go to "Settings" and then to " User Preferences" then "shortcut Menues" there are a few selection you can make - Enable Default mode shortcut.....,Enable Edit mode shortcut.....,Enable Command mode shortcut...., and so on. Good luck!
0 -
Bcad not starting actually alerted me, after a little digging, that some lisp behaviour had changed in line with Autocad and that in turn has helped solve a few subsequent problems.
0 -
@Alex K.
Thank you for your suggestion. I had them all enabled except 'Enable command mode shortcut menus only....'
enabled tat one too, let's see.....
greetings
Sander de Geus
0
