Segmentation fault (core dumped)
I'm getting Segmentation fault (core dumped) whenever i try to start the program on my Ubuntu 10.10
Here is the complete error
(bricscad:23278): Gdk-CRITICAL **: IA__gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
  • I'm getting the same.
    Trying different things to get it working, if you close the initial window (file menu, then close) and open a file, thinks work (zoom, drawing, etc). But then, if you open a new file without closing the recent opened file, you can't do nothing inside any opened tab (also you can't close any tab) and if I scroll down or up inside the main drawing area, Bricscad close with this message:
    (bricscad:7389): Gdk-CRITICAL **: IA__gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
    Segmentation fault
    I guest this is a bug...
    Thanks a lot any way for bringing DWG to the linux comunity....
  • Having the same problem on Kubuntu 10.10, program starts but after opening a file it crashes. In Kubuntu 10.04 everything works fine.
  • I reported this weeks ago. There is one workaround: switch to paperspace or to modelspace with command mspace or layout. After this program works as expected.
