request for information on setting up a BRX project
Before I can do some  programming in BRX I think I need a short overview how to set up a  simple BRX project (in Visual Studio), and I wanted to know if anything  like that is available on the web, especially if there is a template  project.
It did not help that the documentation talks about a  sample project but I didn't find any in the latest SDK. In the "Files To  Share" section I found two BRX projects which may be very helpful.
Of  course I could also get the information from resources related to  ARX/AutoCAD. I have already set up ARX projects, but that's 7 or 8 years  ago, and I would like to avoid the mistake of applying these solutions  by try and error to BricCAD.
Thanks in advance for any help.
I think there is a BRX sample that comes with Bricscad. There are a few samples at www.theSwamp.org as well : )
0 -
Hello Christian,
The BRX sample is installed with the application in %ProgramFiles%\Bricsys\Bricscad V10\API\brx by default.
There are some discussions at theswamp.org that include sample projects for use with Bricscad. I am not a professional developer, I just tinker to server my own uses so others can give better advice regarding setting up a flexible solution.
0
