Why Bricscad doesn't support saving multi-menuload?
If I load more than one customized menus,it can't appear again if I closed Bricscad.
So is it that Bricscad can't support saving multi-menuload?
Do you use:
File > Load partial CUI file...
in the Customize dialog? -
Hello,
I am not sure what exactly you mean? If I load two CUI files in Bricscad, say MenuA.CUI and MenuB.CUI, close Bricscad and restart again, I can still see them loaded. I see no problem here.
Is there anything else in your question that I did not understand?
Regards
Rakesh Rao
Blog: http://rakeshrao.typepad.com -
Thank u for replying:)
I am sorry I didn't express myself well.
Yes, what u said is ture.
I know that I can load more than one partial CUI if I retain the Bricscad default CUI file, and they can be reserved.
Now the problem is that I've made a CUI file which contains menu bar, and I replace the BricsCAD CUI with it.
So under this contion,I can never see MenuA.CUI and MenuB.CUI after closing Bricscad and restarting it again.
I am sorry,for my poor expression.Thank u again.
Check this post:
http://www.bricscad.com/common/support/forumthread.jsp?id=12439
#3: minimum for a main CUI
#6: menu container -
Thank you Roy and Rakesh.
Roy,thank you for your point.
Following your thought,I find the code concerned the partial MenuFile in the default.cui
<?xml version="1.0" encoding="UTF-8" standalone="no" ?><CustSection xml:lang="en-US"> <FileVersion IncrementalVersion="2" MajorVersion="0" MinorVersion="3" UserVersion="0"/> <Header> <CommonConfiguration> <CommonItems> <PartialMenuFile>C:\MenuA.cui</PartialMenuFile> <PartialMenuFile>C:\MenuB.cui</PartialMenuFile></CommonItems> </CommonConfiguration> <WorkspaceRoot> <WorkspaceConfigRoot/> </WorkspaceRoot> </Header>
So in conclusion, We can make a main CUI,that contains customzied CUI, by adding the file address between
<PartialMenuFile> </PartialMenuFile>
Regards
LL
Howdy, Stranger!
