pdf export
Hello when i export to pdf the draw is exported also with line colour, how i have to do for export draw only in black?
Thanks
  • @Luca Bertolotti
    what method you used("export as pdf" or  "cups-pdf")?
  • Luca, there is a nifty thing called "Plot style tables", available in page setup. You could use "monochrome.ctb" there. Or create a "grayscale.ctb" yourself, which would map all colors to some gray.
