V12.Net API: How to get and entity by its handle?
Hello all,
I've started to play around with the .NET API in V12 (using C#) and run into following challenge:
How do I get reference to an entity if I know its handle?
Actually I look for a specific Paperspace Viewport (by its handle)
Do I have to cycle the Paperspace block (using a BlockTableRecordEnumerator) until I find an entity with the correct handle or is there a quicker way?
Huge amount to (re) discover after 10 years playing with COM!
T.I.A.
Arno van Eeuwen
Hmmm, never mind. This seems to do it.
http://through-the-interface.typepad.com/through_the_interface/2007/02/getting_access_.html
0 -
On with the .NET quest...
Document doc = AcAp.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor editor = doc.Editor; try { long ln = Convert.ToInt64(rxConfig.Handle, 16); Handle hn = new Handle(ln); ObjectId id = db.GetObjectId(false, hn, 0); using (Transaction tr = db.TransactionManager.StartTransaction()) { Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
Some more code here.... }
Now in my case the entity I try to acces using the above code lays on a locked layer.
The GetObject fails....
So: how to make sure to unlock the layer of an entity when I only know it's ID?
TIA
0 -
Transaction::GetObject has an overload, forceOpenOnLockedLayer.... the signature should be
public virtual DBObject GetObject(ObjectId id, OpenMode mode, bool openErased, bool forceOpenOnLockedLayer);
give that a whirl and see what happens
Cheers!
0 -
Why are you not in the pub celebrating your birthday? ;-)
Ah, you brought you own from Belgium!
Thanks Dan, another mistery solved. As I said, loads to discover.....
0 -
I'm headed to the pub now : )
0
