Multiline Dimension Text
I am testing the trial version for a possible switch from AutoCAD and have come to a problem that I can't figure out.
Is the a way to have multiple lines of text in a dimension?
That helped. Thanks. I was trying to do it using the dimedit command not through the properties window.
Howdy, Stranger!
