MText Dialogue Box Position
I have just noticed that, if the main program window is on the primary monitor, everything seems to work properly; the mtext dialogue moves above the text object, however when running Bricscad on a secondary monitor, the dialogue is placed on top of the text and forced to the centre of the screen. Has anyone else noticed this, or is my computer acting up?
Curious, I've noticed the same thing and found it mildly annoying.
To verify I tried an Edit on MTEXT on my laptop here (I'm out of town), and no problem!
When I get home I'll try it on the workstation, and yes, like you, I run Bricscad on my larger second monitor. -
^^Your right, its not as "dual monitor" friendly as it could be
Capture.PNG -
I've tried to signal this quite a long time ago. I got the same problem but the devs answered me that they cannot reproduce. I guess they have worked on the primary mornitor where everything works fine. This thing is pretty annoying when you have to edit a lot of texts.
Please adjust the editor for proper use with a secondary mornitor!
I can confirm this pesky behavior. Thanks nevertheless, in that I never (until now) associated it with my second monitor.... when running Bricscad on a secondary monitor, the dialogue is placed on top of the text...
Howdy, Stranger!
