Editing solids on v13 demo ...how-to questions
I am running the trial version of Bricscad V13, and have some questions with regards to the solids editing.
1) How do you edit the parameters of a solid that has been altered significantly, or an ACIS solid? ie: if you wish to change the diameter of a solid cone that has had a cylinder subtracted from it (see picture)
2) When I set a 3d radius constraint on a conical shell, it does not change the actual diameter/radius of the conical shell. How do I properly apply this constraint?
Thanks!
0
Picture here.
Clipboard01.jpg0 -
Hello Paul,Thank you for your interest to BricsCAD V13.Could you please submit a support request with your .dwg file attached?0
