Exttools?
Does anybody know where I can download Exttools?
I can't seem to find it.
I'm (finally) upgrading to bcad v12.
Has it been discontinued?
If so, I haz a sad, they were excellent.
0
Right here: Exttools0
@Yaacov,
you might like to compare with the built in features of Bricscad V12. See http://blog.bricsys.com/2012/08/tip-working-with-blocks.html
Regards,Jason Bourhill
0 -
That link at the Swamp was where I first looked, but ExtTools.msi isn't there anymore, sorry.
I'm really looking forward to using the Drawing Explorer as a block manager, much neater, I think!
What I really wanted was a tool (in the menu) that came with ExtTool called
"Burst Block" which explodes blocks, converting attribs to texts with the attrib values.
I guess I can dig around the Swamp for something similar with a different name.
Thanks!0 -
I've posted it back on the swamp and also here
http://cadext.com/downloads/ExtTools.msi
Cheers : )
0 -
Thanks!0
Hello, I installed the Bricscad V13.1.15.1 and found the tools that Ext
unable to load it geht.Wird be a version for V13?0 -
Hi,
I have posted a new build for you to try. You may have to uninstall older versions first.
Cheers : )
Daniel
0 -
Hello works without problems, thank you.0
Hello there, it is still a small problem with the V13.Beim call the entire height of Bricscad genutzt.siehe bild.V12 was ok.
0 -
Is the Exttools module for V12 still available?I have had it installed but have had to reinstall Bricscad recently and would like to reinstall Exttools. Installing the available version tells me I need to have V13.Thanks0
Hi Gary, Sorry for the late reply
the link for v12 is now http://www.cadext.com/downloads/ExtTools-v12.msi
0 -
Thanks Daniel.0
Hallo , wird es die Ext-Tools auch für Bricscad Pro V13.2.4-1 64 bit geben ?
besten dank im vorraus0 -
besten dank im vorrausHi,
I will make a build in the next day or two.
Cheers : )
0 -
Thank you very much0
0
