Bricscad jumps to the file directory when closing Drawing Explorer
I find if I have a dwg open and then use Drawing Explorer for any reason Bricscad behaves differently as follows
1: If I open a dwg by clicking on it inside its own Directory Folder then when I use Drawing Explorer and close it, the parent directory of the dwg comes to the front (obscures Bricscad window) which is annoying.
2: If I first open Bricscad then a dwg then Drawing Explorer and close, I am returned to the Bricscad window.
I find it much easier to just open a dwg from its directory.
Is that considered a no-no?
Might have to curb my old habits but wonder if there is a bug in Bricscad that causes me the problems?
regards
  • I used to have the same problem in early Versions of V12. However, sometime ago it got fixed.
    Which version of Bricscad are you using?
  • I'm using 1.1.4 build ID32852 Rev 24087, Platinum
    May not be latest, but I found it rather tedious to update and get my most used third party applications installed and running correctly.
    I've been toying with ver 13 idea.
