Alternative for AutoCAD Map 3D?
Hi
Could you recomend any good solution for BricsCAD that could replace AutoCAD Map 3D?
Functions that are needed:
- Topographical data access and editing
- GIS analysis and planning tools
- Industry data modeling and management
Thanks in advance
Dominik Beśka
Thanks in advance
Dominik Beśka
0
Hello Dominik,
You may want to look at two value products that offer functions similar to AutoCAD Map. Neither will provide you all the functions from Map but each one has its own strengths and limitations, and are popular with BricsCAD users.
1. MapWorks for BricsCAD - from www.dotsoft.com
2. GeoTools for BricsCAD - from www.coordsys.com
- Rakesh Rao
http://rakeshrao.typepad.com0 -
            Hi Dominik,There is also intelliMAP, in French version, wich provides you lots of GIS functionnalities and topographical drawing functions.Internet site: www.intellimap.frSeveral videos concerning this product:Etienne MOROTechnoGIS0
http://youtu.be/AkDeG_RVHdI
http://youtu.be/2oe4CSKjQiE
http://youtu.be/5i0zLJIXn6M
http://youtu.be/xxLNx-tn7-k
