Wrong rectangular area printing
 The window print option of BricsCAD Linux doesn't work correctly  from the first version (BricsCad 10) : after selecting a rectangular area to print, BricsCAD prints all objects within the area and outside it, so this option can't be used. Is there a workaround to this?
Thanks
  • The ugly workaround is to use viewports.
  • Probably no joy for you but Bricscad 3.2.11 seems to work ok using Select Window > Centre the Plot > Fit to Page > Landscape. The window area can be seen in the Preview screen.
  •  Thank you very much Andrey and Brian, but your hints don't work. I'll try to submit a support request to Bricsys.
