IGS export in V14
Is it possible to get the export functions for STP and IGS enabled in the trial version of V14? I have a platinum V13 license, however I would like to evaluate the 3D export capabilty of V14 but it seems restricted in the trial version? Barrie
0
The import/export of STP and IGS files is enabled by the Communicator module, which needs to be installed separately. You can download the installer from the Bricsys website at http://www.bricsys.com/en_INTL/bricscad/communicator/. Make sure BricsCAD is not running during the installation. When the installation is finished, launch BricsCAD and activate the Communicator trial license in the Help menu.0
hello Louis
Thanks for the info, I will do as you say.
Barrie0
