Building for both: Bricscad .NET API and Autocad .NET API
 Hi
I need to develop for both, Bricscad AND Autocad.
As I learned here (https://forum.bricsys.com/discussion/20400) that the .NET interface is source compatible, but not binary compatible.
Is there a documentation or a sample VisualStudio-project which shows, how to easily build a library for Bricscad AND Autocad?
I assume that I need two VisualStudio projects sharing the same source code.
Thanks!
  Hans
