problem - Setting the UCS to WCS does not work
 Bricscad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem = Matrix3d.Identity;
does not change the coordinate system
In AutoCAD
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem = Matrix3d.Identity;
works as expected
In AutoCAD
works as expected
0
            Hello Valentin,
this user forum is meant for user-to-user communication.
To communicate with Bricsys development, please use the support request pages: this sounds like an issue that you may want Bricsys development to correct?
Kind regards0 -
            excuse
I'm new and do not know where these pages
"support request pages"
Kind regards0 -
            On www.bricsys.com click the SUPPORT option in the black menu bar along the top of the page to navigate to the main Support page - there, click on the blue Support Request button at the bottom left. From there on it should be straightforward.
Kind regards0 -
            thank you0
