HOWTO: BricsCAD 13 in openSUSE 13.1 64 bits
I finally found some time to install oS 13.1 x86_64 on a Netbook with ATI graphics and SSD drive.
Getting BricsCAD Pro 13.2.16 to install was easier than I thought after reading the OpenSUSE KB here: https://www.bricsys.com/common/knowledge/topic.jsp?id=317 , I just had to remember that BricsCAD require the -32bit compatibility versions of the 64-bit libs. So, what I did was:
1) Install BricsCAD RPM from Yast, that will pull in a couple dozen -32 libs. This can be done with zipper too, for those used to it (I'm not).
2) Download (or do the 1-click install) from OpenSUSE software site the two following libs, easily found with the download site software search - remember to change the options to include development packages:
libgnutls26-32bit-2.8.6-5.27.1.x86_64.rpm - search for libgnutls26-32 and download (or 1-click install) the 64-bit package from Ximi1970's OpenSUSE 12.2 repo
libtasn1-3-32bit-2.12-2.2.2.x86_64.rpm - again, search for libtasn1-3-32 and download (or 1-click install) the 64-bit package from the official OpenSUSE 12.2 repo
I used the 12.2 repos since there's no 13.1 packages yet, and probably there won't be. I didn't try the factory packages but the'd probably work too.
Of course, you could just download the three packages (BricsCAD and the two libs), put them in a folder and set it as a RPM repo in Yast, then install everything in one pass.
Then I started BricsCAD, entered the Pro key and tested by opening, editing and saving a 2D work drawing as a new file, without problems.
In the next weeks I'll post in case of problems. If I don't is because there were no relevant issues.
I hope the above may help someone.
Note: the same procedure works with OpenSUSE 12.3 x86_64 with NVidia graphics.
Howdy, Stranger!
