Explode AEC objects
I've got an AutocadArcitecture drawind filld up with AEC Objects.
Bricscad is able do show them all correctly, but they are not editable or explodeable.
Is there a way to convert them into standard CAD elements, or do i have to ask for an drawing which was saved by using 'ExportToAutocad' in ACA?
0
Dont know if anything has happened. http://forum.bricsys.com/discussion/88240
"-AecExportToAutoCAD allows you to convert an AutoCAD Architecture or AutoCAD MEP drawing to AutoCAD entities. The command gives you the ability to bind xrefs and save the file in 2000, 2004, 2007 or 2010 drawing format. The result will be exported to a new DWG file with all AEC objects exploded."
-AecExportToAutoCAD creates a new version of a drawing file with all proxy AEC objects exploded into basic objects. The new version of the drawing loses the intelligence of the custom AEC objects, but the resulting basic objects can be displayed and accessed in earlier product versions when object enablers are not available.0
