Status Bar
I'm using Bricscad Pro Version 14.1.13. My computer has crashed and would not reopen my drawings. When I finally was able to retrive my drawing, my status bar icons are gone. I have opened, closed, reopened, rebooted, you name it. The status bar is there just no tool optionals. Help!
0
Hi Scott,
You mean BricsCADs standard menu is not displaying? You can reset this by typing _CUI at the command prompt, Then select the "Revert to Defaults" button in the bottom left of the window that opens.
If it's not that, then you can try creating a new user profile. If BricsCAD then works ok, then original profile was corrupted in someway when your computer crashed.
Best regards,Jason Bourhill
0 -
Try typing STATBAR and following prompts. If the status bar is on but no tools are available, there should be a small triangle at the right end of the status bar. Click on it and select the tools you want to display.0
No triangle.0
Hi Scott:Check that the status bar is checked in the View menu, it is near the bottom. You could also try the command WNDLSTAT and set it to OnScott0
The status bar is on. Just none are the icons are on the bar and the triangle (opening) is not on the right side. I cannot add any items to the bar. Cannot find any options for the staus bar under Setting other than off and on. Can't find a way to get the icons on to the bar.
0 -
Dear ScottPlease follow the instructions by Jason in reply #2: restart BricsCAD using a fresh profile with hard-coded default settings.0
