BricsCAD Load Time
Do you have an Anti-Virus software running ? Try with disabled AV then, to see if that makes a difference ?
Many greetings !0 -
I've had the same experience. V14 takes almost a minute to load, compared to just a few seconds for V13 (on the exact same machine, OS, etc).Once it's loaded V14 seems to run just as fast as 13.0
Mine loads very quickly. A little slower first time after starting the machine and using internet, my usual routine.
I use minimal virus security with real time protection turned off, many would say that's not too smart but I don't have many OS issues.
0 -
Curious. I still have v13 on my netbook (w/ it's paltry Intel Atom processor) and v14 loads in 7-8 seconds, v13 takes a couple seconds longer.
On desktop machine v14: 5MB dwg opens in
seconds.<br>0 -
v14.2.06 opened here in about 3 seconds on my desktop on the first run of the day. I have noted that the time to open a new instance of Bricscad can vary during the course of the day, but the most I recall it taking is around 15 seconds. I run Bricscad with one drawing per instance of Bricscad so it is not unusual for me to have six or more instances open at any time.0
