Function "Mirrtext"
I would like to know the best way to me
· Function "Mirrtext" does not work on texts by "Leaders" and "Multleaders";
Thanks,
Eric Rodrigues
0
It works here (v14.2.10)0
... There is a problem with multileaders: The mirrored version has the text upside down.0
Olá,
"O mirrtext está funcionando na v14.2.10. "
- Esse comando não funciona com a entidade "Multleader". Em texto "soltos'" funciona perfeitamente, mas com essa entidade não.
"It works here (v14.2.10) "
- This command does not work with the entity "Multleader". In text "loose '" works perfectly, but with that entity no.
Eric Rodrigues.0
