Acrobat x paper sizes
I just installed acrobat x on my machine. I don't seem to have any of the standard architect paper sizes. ( A B C D E, Arch A Arch B .....)
any ideas ?
JP
any ideas ?
JP
0
Assume you have the "Standard" version? I believe Arch paper sizes are only supported by the "Pro" version.
Suggest alternative viewer (many are free).0 -
All Paper is supported by x standard per a "dear customer reply" on the adobe forums.0
Assuming you are using BricsCAD, why not use EXPORT to pdf?0
I tried the export to pdf a few times and was not able to get the scale exact. The plot interface is also much better for control.
I installed the postscript drivers that allowed me to define custom paper sizes, so problem solved.
JP0
