How to launch BrisCAD from Excel VBA
1. How to launch BricsCAD from excel VBA(2003)
2. Do I need to append "BricsCAD APP 11.0 Type Library", "BricsCAD DB 11.0 Type Library" or others from EXCEL VBA ?
3. How can I draw polylin,text,dimension fom EXCEL VBA to BricsCAD?
4. Any other examples in your Web site?
5. Any eBook about BricsCAD VBA manuals ?
Thanks,
Joe
  •  Here is a example of AutoCAD.
    How to modify the code can run in BricsCAD?
    Public Graphics As AcadApplication Public Sub OpnAcad()     Dim strDrawing As String    On Error Resume Next    Set Graphics = GetObject(, "AutoCAD.Application")    If Err.Description > vbNullString Then        Err.Clear        Set Graphics = CreateObject("AutoCAD.Application")    End If    ' ACAD.Visible = True    strDrawing = "c:\0\Test.dwg"    Graphics.Documents.Open (strDrawing)     On Error GoTo 0End Sub
  • Hi Joe,
    you need to update the application reference
    [code]Public CADapp As AcadApplication
    Public Sub OpenBcad()
        Set CADapp = GetObject(, "BricscadApp.AcadApplication")
            Err.Clear
            Set CADapp = CreateObject("BricscadApp.AcadApplication")
        End If
        strDrawing = "D:\Temp\TestDrawing.dwg"
        CADapp.Documents.Open (strDrawing)
        CADapp.Visible = True
        On Error GoTo 0
    End Sub[/code]
    Note you have to include BricsCAD in your references. See screen grab attached
    Regards,
    Jason Bourhill
    CAD Concepts
  • Joe,
    Should of also said to look at the Developers Reference
    There are a number of examples under the COM section
    Regards,
    Jason Bourhill
    CAD Concepts
  • How can I draw "line" from Excel VBA to BrcisCAD?
    The example in attached file
    LaunchBricsCAD.xls
  • The only issue I ran into, when I did the same, was that both the BricsCAD and Excel programs need to be set to run as administrator.
    -Joe
  • Alikhan
    edited July 2023
    https://www.bricsys.com/bricscad/help/en_US/V17/DevRef/source/VBA_VBA.htm read this post yah it helped me thank you nice source
    Regards
