layers
Hi, a few little niggling things I am having trouble with
1. Are you able to apply your layers filter to the drop down layers dialogue box?
2. How do I turn off entities highlighting when I hover over them?
3. How do I switch off the tool tip that keeps popping up and getting in the way?
Thanks
Richard
0
Hey Richard,Not sure about number 1, you could probably build a function in the CUI but only I wouldn't go there, CUI is a whole world of pain (for me anyway).2 - Options / Selection / Selection preview displaySelection effect is Bold or Dashed, or Both. Unfortunately no option non. Same as acad in that respect.3 - Options / Display /There are a few tool tip options under here and it should be one of themHopefully they are rightL.0
Dear Richard1. Choose Drawing Explorer > Layers in the Tools menu. Check 'Apply layer filter to layer toolbar' in the View menu on the Drawing Explorer - Layers dialog box.2. Set SELECTIONPREVIEW = 0 or 23. Set PROMPTMENU = 0Kind regards0
I forgot to mention that SELECTIONPREVIEW is neglected when the QUAD cursor menu is active. Press the F12 function key to toggle the Quad on/off. You can check the current status of the Quad in the Status bar: Quad field at the utmost right. Clicking the Quad field also toggles the Quad on/off.0
Thanks Louis, I was just wondering where to find the first point.
TOm0 -
Easy when you know how!Great, thanks everyone. I am coming over from 20 years on AutoCAD, and the smallest little differences are throwing me, but I am gradually getting up to speed.Richard0
You're a star Louis!0
