Install BricsCAd V14 in Debian Wheezy
Hi! I have installed the version V14 in Debian Wheezy KDE
It looks to be installed but when I try to run the application, nothings happends.
Anyone knows what is the problem?
what schould I do to have the programm working?
Thanks a lot
Jairo
Thanks a lot
Jairo
0
Hello Jairo,
the BricsCAD deb installer was designed for Ubuntu.
Likely on Debian not all dependencies are automatically installed.
You can use ldd to find out about missing dependencies, see the section "More information" on the bottom of this knowledge base article:
https://www.bricsys.com/common/knowledge/topic.jsp?id=305
Regards
Tijs0 -
BricsCAD has always worked for me in Debian. I ran V13 in Debian Wheezy and I'm currently running V14 with Debian Jessie.
My guess is that the program won't launch because of some small error condition which could be fixed. Did you try launching the program from the command line to see if it emits an error message?
Open a new terminal and cd to where BricsCAD was installed. For example, do:
[code]cd /opt/bricsys/bricscad/v14/[/code]
Then try running BricsCAD using the bricscad.sh script. For example:
[code]./bricscad.sh[/code]
Does it start that way? If not, does it give an error message?0 -
Thanks! That was helpful. I can't open it but now I know why.
I am trying on Debian jessie and it works.Hello Jairo,
Regards
Tijs0 -
Thanks for your interest.
I receive this: version `GLIBC_2.14' not found
Debian Wheezy uses the version 2.13
But now I try on Jessie and it works
Thanks!BricsCAD has always worked for me in Debian. I ran V13 in Debian Wheezy and I'm currently running V14 with Debian Jessie.
Open a new terminal and cd to where BricsCAD was installed. For example, do:cd /opt/bricsys/bricscad/v14/
Then try running BricsCAD using the bricscad.sh script. For example:./bricscad.sh
