Educational licence
Hello,
I got educational licence for Bricscad and would love to use this licence to teach Bricscad in school. But I get a problem, because if I use licence key on 1 machine, i cannot use it on another. During activation I get:
What can I do?
Check the licensing FAQ. You require a separate license per seat. If you want to use the same license you need to uninstall or unregister the previous machine before.
And probably ask Bricsys to authorize the hardware change, as IIFM the license is locked to the first hardware it's installed on.
Oh okey. I thought that this is a licence for multiple computers...
Hello,I got educational licence for Bricscad and would love to use this licence to teach Bricscad in school. But I get a problem, because if I use licence key on 1 machine, i cannot use it on another. During activation I get:What can I do?Hello Ziga,The most probable cause is that your license is for your personal use (an individual license) for educational purposes. If you are a teacher and you teach lessons on a regular school, you should be able to request a laboratory license for installing in all your stations for classes. This other kind of license is a Volume license which will be granted yearly for your academic institution.I suggest you to ask for assistance of your local BricsCAD distributor.HTH,Miguel
Thank you all very much. This is the anwser that I needed.
Howdy, Stranger!
