Hatch Pick points
Hi,
Can someone tell me how i get pick points to a hatch?
I want pick points in the corners of my hatch so i can edit them easily. Now there is only a pick point in te center of the hatch.
Grt, Tim
0
In BricsCAD V14 and older, non-associative hatches have a center grip. In BricsCAD V15 additional corner and midpoint grips are available.0
In V14 you can use the HATCHGENERATEBOUNDARY to generate the boundary of a non-associative hatch, then use the Reassociate option of the HATCHSETASSOC command to associate the hatch with its boundary.0
Is there no other way? I just bought V14 pro and this is a big disappointment for me!0
No there is no other solution.
Download V15, run it as trial and check out the hatch there.
V15 comes also with a Ribbon menu and BIM version.
Keep in mind that the tirial is V15 Platinium.
Like the test? Upgrade to v15.0 -
Is there no other way? I just bought V14 pro and this is a big disappointment for me!I believe you ordered BricsCAD earlier this month, so you already have a BricsCAD V15 enabled license key. You should be able to simply download BricsCAD V15 and start using it.Best regards,mark0
