wheel click not showing osnap menu
I set MBUTTONPAN to off, but my osnap menu is not showing when I wheel click.
The pan did work when mbuttonpan was on, so I know its not misinterpreting the wheel click.
a shift-right click does show the osnap menu.
The CUI shows blank for middle button click, is that a bug in v15?
my main menu is default.cui, straight OOTB. I am on a win7 64 bit dell cad level laptop.
any ideas?
here is my cui for appropriate section:
0 -
Try setting the middle mouse button to Autoscroll in WINDOWS. ACAD has had this issue in the past, it appears to only happen with certain mouse manufacturers.
I've done that, as I know how with acad you need middle button for MS mice, and autoscroll for logitech drivers.
Its not helping though. I also tried on version 14 and same issue. It just seems odd that realtime pan works with the wheel click when mbuttonpan is on, but osnap menu would not. The CUI looks good, its just not working. I'll try on some other machines.
0
