realtime updates between drawing explorer (layers) and main-map
I have 2 screens.
(In AutoCAD) I use to have the main-window one screen 1 and the (drawing explorer with) layers on screen 2.
In BricsCAD, when the drawing explorer is activated, the main screen is deactivated.
When I change things in the layers, I then have to first close the drawing explorer, before changes to apply in the map.
On the long run this costs me quitte some time ....
Is there a setting (or other solution) to change this?
Thanks,
0
Hi,I think that there is a way to create this functionality only by programing (for example in C#)0
I don't think there is any way for the dialog to stay open but you can see the changes interactively while it is open. There is a regen button on the toolbar inside the drawing explorer that allows you to update the display changes. There is also a button that will regen the drawing as you make each change.
layers.png0 -
Thanks for your replies.We will have to do with the regen buttons for now.0
