xref linetype definitions problems
new v15
when xrefs are opened or reloaded the linetype definitions that are layer controlled are changed to continuous lines
0
            Yes I have faced the similar issue.0
            Me too. This has to be fixed.
When I first attach an xref everything is ok. I close the drawing with the xrefs attached and open it again and the xref's layers are all continuous linetype. They display AND plot incorrectly.0 -
            0
            Same here in version 15.1.16
Undefined LineType
AcDbLayerTableRecord(1BB4E)
is reported when the drawing is being reopened for each xref's linetype0 -
            FYI,
we are preparing an update release for the coming days. It will contain a fix for this problem in the Teigha libraries.0 -
            many thanks for the new update that fix the problem. fast and good work
regards jürgen0 -
            Tumbs up!0
            Xref related:
Check that xref and you drawing use same LTscale value and ddunits value.
If the architect creates drawings in meters and this was not changed/updated,
set ddunits to meters , even if the dwg is indeed mm0
