LAYERP in Bricscad V15
Hi,
I'm trying the LAYERP command in Bricscad V15.
I often use this command in Autocad after isolating a layer.
But on Bricscad, LAYERP only unfreeze layers one by one.
This is very annoying after isolating one layer among hundreds.
Is there a parameter to unfroze together all this layers ?
I know the layer state commands but this is really too long.
Thanks
Thanks
0
Dear PhilippeFor the procedure you describe you do not need the LAYERP command. Please use LAYISO (Isolate layers) and LAYUNISO (Unisolate layers) instead.0
Hello
Thanks for your reply. This solves most of my troubles.
But there's still the case when I freeze a lot of layers at one time using the drawing explorer ( eg all layers starting with blabla* ).
Maybe I should send a support request ?0 -
With groups of layers with my typical names, I still find it easiest to run script files to freeze and thaw them.
Picked from my menu, they contain simple strings such as -LA F BW* T DW*0
