Xref logo's are not removed by purge Bricscad V15 platinium
Support request is not working at this moment so...
2D architecture.
I open a architecture with autocad2015 (trial) and I see 4 Jpeg's under X-ref
Also when the drawing is openened with Dassaults Draftsight.
Bricscad does not show these not referenced logo's , why doen't purge delete this?
In the zip, the dwg( no acad dwg)
also two jpegs ,
one view within Autocad 2015 , one with Draftsight.
If the dwg is openened with V15 platinium, these 4 logo's are not seen by xref and sure not removed by purge.
  • I see the jpg files in V15.1.20 by issuing the LAYER command at the command line then selecting the IMAGES option.
