V15 small bug
After DXF out and dxf in and save as dwg , then this dwg is removed.
Now I select open , but the type stays locked as DXF, not DWG
Can someone verify this?
Note, no can not fill in support request since no subscription.
0
Stefaan,
DXFIN uses the same file dialogue as the OPEN command. Importing a DXF has changed the default filetype to .dxf. To change back simply select .dwg from the file type drop down. Attach screen grab to illustrate. Closing and re-starting BricsCAD will also cause OPEN to revert to using .dwg
Also you don't need to have a subscription to file a support request. Simply go to the support section of the website, and if you don't find an answer to your question in the knowledge base, raise a support request from there.
Regards,Jason Bourhill
OPEN_Drawing.png0
