Block insert
Hi having used another since long dead cadsystem I still miss a little feature. I would like to have two insertpoints on a block ( maybe even 3 för 3D). First piont fixpoint second Point direction and/or scale. Its very useful to scale graphically when inserting. Anyone knows how to achieve this??
0
When you get the insert dialog box, there are check boxes above the insertion point, the scale, and rotation. You can either pre-set them in the dialog box, or you can indicate them on screen.-Joe0
Yes and no I would like it to work like the align command. Very useful .0
