Viewport bouny visible in tif image
We need to generate tiff images using Landonline "Print-to-tif" driver. When the tiff is created, the viewports boundaries appear as lines in the tiff image. Is there a way of printing without the viewport lines being displayed?
0
In the layers dialog box, you can choose any layer to not print. If the layers with the viewports is set to not print, then they should not show.-Joe0
Grant,
Also check your setting for IMAGEFRAME
The help is a little out of date. Imageframe can be set to the following values:- 0 = Imageframe is OFF, and won't print.
- 1 = Imageframe is ON, and will print.
- 2 = Imageframe is ON, but won't print.
Regards, Jason Bourhill CAD Concepts0
