mkltype command
Does Briscad have a similar command to create complex
linetypes
0
The free Express Tools includes mkltype0
Thanks. Where to I go to get these free express tools?0
Check out "Store" above: Application Catalog / Free Tools.0
On both my laptop and desktop systems with Bricscad v14, I have never been successful in getting the mkltype command of the express tools working. I get the error in the attached screen grab. It is not English, so I don't know what it says.-Joe
Mkltype error.jpg0 -
From Google translate:
Tip: You should set the global LTSCALE to 1 ! ( Command LTSCALE / _LTSCALE ; aka LK )
I haven't tried the Express Tools so I don't know if there is any problem other than this.0 -
Thanks for the effort to help. I have now set my ltscale=1, but there are more errors. Here is a copy of the command prompt from my test.============================================: MKLTYPEEnter linetype name: test1Enter linetype description: just testingSpecify starting point for line definition:Specify ending point for line definition:Select entities:Opposite Corner:Select entities:; ----- LISP : Call Stack -----; [0]...C:MKLTYPE; [1].....MKLTYPE_FORMAT2 <<-- </div>;; ----- Error around expression -----(STRCAT B A);* bad argument type ; expected at [STRCAT]============================================My entities are two lines, with some text. The font is "standard" with the "txt.shx" font file. I get the same error if I only select the two lines.My guess is that I am doing something wrong, and the program just is not doing a good job of telling me what I should do. Any suggestions about how to work around this error?-Joe0
Maybe you should try http://www.theswamp.org/index.php?topic=47058.0 You may have to do a free sign-up. theswamp.org is an excellent place for help in programming for Autocad and Bricscad.0
Nice find Martin.
I was there earlier, but didn't find that routine.0
