Graphic
Hi List,
i'm starting to look for a new Desktop PC. Is there any recommendation about Graphic Cards?
Thanks
  • It depends on what you plan to use the computer for.  For 2D drafting and basic word processing the video integral to the CPU may be all you need.  If you will be rendering or gaming the answer would be different, but it would also be somewhat dependent on the exact programs you plan to run.
  • Hi,
    thanks for the answer.
    I'm using Briscad for 3D drawing and Rendering.
    Jonas
