Images are dark/black when printing pdf. images are not in the right possition.
Hi
I have 2 problems:
Images are dark/black when printing pdf.(in autocad i don't have this problem)
Images in autocad position in the right place and in bricscad not.
anyone?
peace
Barak
  • Please file a support request and attach the drawing and the images. Use the eTransmit command to compose a zip file, which contains all files needed.
  • how do I file a support request ?
    when i try to file a support request  i get a search in data base :
    https://www.bricsys.com/nl_BE/support/
    peace
    Barak
  • Dear Barak
    On the Support page, click on 'BricsCAD', and select 'Printing & Plotting' on the next screen. You then see a list of available topics about printing. If the problem you are facing is not in the list, click the 'New Support Request' button.
    Kind regards
  • For black output I would start checking my pen settings.
  •  I had the same problem when using the Bluebeam PDF printer driver. I changed to the PDF -Xchange printer driver an the images print ok.
    So maybe try another PDF printer.
    Walter
  •  Please notice that PDF printers have a 'Black & White' option on the 'Paper/Quality' tab of the Properties dialog.
  • Thank you,
    i will try to use another pdf plotter.for my second problem i attach 2 phot's:
  • this is how it comes in autocad
  • Hi Barak,
    this is the user forum, intended for user-to-user communication.
    If your intention is to report a problem to the development team, please file a support request and attach the files required to reproduce the issue.
  • Hi Hans,
    sorry but i don't know if it's a bug or something that i do wrong.
  • Well, if you file a support request we can investigate it and provide you with a solution...
  • i will do
    thanks
  • Hi,
    i found what was the problem with the dark images:
    in the property window of the image in- MISC and then -  Backround Transparency-it has to be on "NO"
    peace
    Barak
