Express Tools for V15
Thank you for the answer.
I am sure that use ExpressTools for BricsCAD V15.
Just in case reinstall ExpressTools from http://www.cadwiesel.de/index.php?hp=downloads&anzeigedatei=downloads&download_id=244
Nothing has changed. TCOUNT still don't work with "Sort selected objects by" X/Y.0 -
Many thanks for feedback ....
I will check the problem with Martin Drese ... and keep you update dhere.
Many greetings !0 -
hi, i am jerry, someone can help me to install Express tool on my pc, i have a V15 version,this note is repeating when i start a new drawing: ; error: LOAD failed: 'Acetutil.des'thkjerry0
Torsten Moses said bellow:" The easiest way is to to add a "on_doc_load.lsp" to ./Express folder, with this content
(load "Acetutil.des")
If you already have such an "on_doc_load.lsp" on another folder, you can also add that statement there."
Be sure to get the correct version compliant ETolls for your Bricscad. I had that problem running a version not compatible with my OS.
Good luck and regards,
Luis.
0 -
Many thanks Luis, I will try it and let you knowBest Regards,Jerry0
And how about this error, after installing Express?: RTEXTBKG_Rtext - Program version 20141107Copyright (c) 2011-2014 Roy Klein Gebbinck - All rights reservedUse: BKG_Rtext BKG_RtextEdit BKG_RtextUpdateOr: BRT BRTE BRTUCurrent settings: Style=_A2P Texto Height=0.25000000 Rotation=0Enter an option [Style/Height/Rotation/File/Diesel] : D; ----- LISP : Call Stack -----; [0]...C:RTEXT; [1].....FETCH; [2].......ACETRTEXT:PICKTEXT <<-- </div>;; ----- Error around expression -----(ACET-UI-TXTED STR "Edit RText");* no function definition
; expected FUNCTION at [eval] Please help. What's hapenning??
The Diesel Option uses the OpenDCL Runtime. Please make shure, you are on an Bricscad Pro and the OpenDCL is the right version on your Machine. Bricscad Classic wont support the *.brx Applications.
Martin0
