Express Tools for V15
- I thought I read somewhere that some of Express Tools are now built into V15. True or False?
- I see there is a version of Express Tools for V15 but I cannot download it from either the Bricsys site or from http://www.cadwiesel.de/
Anyone else have this problem. Does anyone have the Tools that could email them to me?
2. Express Tool's Bricscad Applications DL link doesn't seem to be working here either, but it works fine at the Cadwiesel website.Also, BcadTools DL works fine in Bricscad Applications, as well as lt-extender.com website.0
Hi there,
I am still having a problem, now I can download the ExpressTools_BricscadV15.zip file but it won't open.
WinZip reports the following error: "Error: Central Directory Not Found"
Still hoping to be able to install these tools.
Phillip0 -
I'm also having problems. Downloads fine, but Windows cannot seem to open open the zip file.
Would be nice to have
Ami
I can confirm issues when trying to extract in Windows.Extracting using 7-zip, however, works properly.0
Still needs tweaks for Bricscad 15.
for instance:
Layman is just layer in V150 -
Extracted with 7 zip now, works fine.0
Thanks all
Ami
I agree with Stefaan Coddé,V15 of Express tools seems to needs tweaks.I'm sorry to say that because we rely on these tools, moving our computers to V15 of Bricscad is going to be hindered.Sorry Bricsys0
Which of the Express Tools are you having trouble with? There may be other lisp routines that will do the same things or there may be re-writes that were done before the package from cadwiesel was released.0
I finally installed v15 for evaluation.Also installed latest Express Tools, as well as BCAD tools.Both appear to function as they did in v14 before.0
I would like to know how to install Express Tools
Ami
You can find Bcad tools and Express tools, along with other free stuff, on the 'Free Tools & Add-ons' page of the Applications Catalogue http://www.bricsys.com/common/applications/?estore.ApplicationCategory=16
Oops, I accidently replaced Ami's last response with my reply. Sorry for that Ami.0
No problem
Ami
Extracting the files using the 7zip program was the least of my concerns. It was a bit inconvenient but I got it done.However, I was a little sceptical when the file to load is (load "Acettest.des") instead of (load "Acetutil.des"). The word "test" indicates to me the program is probably not ready for prime time. Then as I played around with the program...
- Some of the routines fail to execute
Examples:
Unable to recognize command "CURLAY"
error : no function definition
(- TPOS 1) ;* too few / too many arguments at [ACET-UI-GETFILE]
(and numerous others) - Some of the dialogue buttons and boxes are still in German and not English
- When I uninstalled the Express menu and restarted BricsCAD it would load the toolbars but not the Express menu. I had to go search for the CUI file in the support path and reload that to bring back the menu bar list of Express tools.
I wish there were a way to get this de-bugged and running again. They are a great set of tools.0 - Some of the routines fail to execute
@ Phillip: Have you tried to get in touch with Martin Drese (a.k.a. Cadwiesel)?0
@Phillip Rutledge:
...unable to recognize command "CURLAY"...
This was also the case with v14 Express Tools.
An easy fix is to Customize the Menu Item, changing the Command from:
^C^CCurlay To:
^C^CLaycur
I'm sorry, I cannot comment on your other issues.0 -
Try LAYCUR
Did anyone ever get Express Tools to download to BricsCad Classic?
Getting Express Tools to download to BricsCad Classic has been such a headache. I still can not get it to work.
div>
blockquote class="Quote UserQuote">
I did notice that it is missing these file extentions, which is needed to create a menu.
.cui
.cuix
.mnu
.mns
.icm
now i'm back in the real World and try to help.
We changed the Server and it seems the downloadpackage was broken, while moving from the old to the new server. Now i upd a new Package. I hope the faults are over now.
Please report if something won't work.
Martin0 -
Sorry Martin, ExpressTools_BricscadV15.zip still doesn't open in windows explorer or winzip. I was able to download it from your website and using 7-zip I was able to extract the files but the end result seemed to be a mix of German and English and some commands/routines didn't work.Sorry.--Phil0
And how about this error, after installing Express?: RTEXTBKG_Rtext - Program version 20141107Copyright (c) 2011-2014 Roy Klein Gebbinck - All rights reservedUse: BKG_Rtext BKG_RtextEdit BKG_RtextUpdateOr: BRT BRTE BRTUCurrent settings: Style=_A2P Texto Height=0.25000000 Rotation=0Enter an option [Style/Height/Rotation/File/Diesel] : D; ----- LISP : Call Stack -----; [0]...C:RTEXT; [1].....FETCH; [2].......ACETRTEXT:PICKTEXT <<-- </div>;; ----- Error around expression -----(ACET-UI-TXTED STR "Edit RText");* no function definition
; expected FUNCTION at [eval] Please help. What's hapenning??0 -
@ Luis:
It seems that Martin has wrapped my functions and something is going wrong.
Try using one of the three original commands: BKG_Rtext, BKG_RtextEdit or BKG_RtextUpdate.0 -
Dear Luis, Dear Roy,
it seems, something got broken when we moved the ExpressTools API (all the acet-xxx functions) directly to Lisp engine core ...
I will check + fix the problem, Martin has provided his sources for ExpressTools commands to me.
So it should be easy to compare + fix.
Many greetings !0 -
Great,Thank you all.Can you please let me know when you get it?My e-mail is:luis.martinho@a2p.pt0
There is a minor issue in ExpressTools by Martin Drese (CadWiesel) …
this problem with RText only happens very rare - when it is just the first command used from ExpressTools :-)I notified Martin Drese about, and it is indeed very simple to fix (I tried on my machine).
Here is a simple workaround :
to have RText working, you only need to pre-load "Acetutil.des" from ./Express folder, for each drawing …The easiest way is to to add a "on_doc_load.lsp" to ./Express folder, with this content
(load "Acetutil.des")If you already have such an "on_doc_load.lsp" on another folder, you can also add that statement therel.
Many greetings !
Also have error in Bricscad v15 (x64):
: TCOUNT
Укажите объекты для добавления в набор:
Противоположный угол:
Sort selected objects by [X/Y/Wahlreihenfolge]: y
Specify starting number and increment (Start,increment) <1,1>:
Placement of numbers in text [Overwrite/Prefix/Suffix/Find&replace..] : o
; [0]...C:TCOUNT
; [1].....ACET-TCOUNT
; [2].......ACET-ESORT
; [3].........ACET-LIST-ISORT
; [4]...........ACET:ISORT <<--<br>;
(SUBSORT2 LST3)
;* no function definition ; expected FUNCTION at [eval]0 -
Dear Sergey,
do you really use ExpressTools for BricsCAD V15 ?
This is the implementation used by ET V15
(defun acet-list-isort (plst index) (isort plst index))
It uses "isort" fucntion, not ACET:ISORT ... please check which version of ET you use;
ExpressTools is specific for each BricsCAD version.
Many greetings !0
