V16 Slice problem with BKS
I have updated to V16 and encounter a problem with slicing:
The slice plane lies always vertical to the view vector - I cannot change it.
I tried to manually set BKS to WKS - did not help.
Is there any klick within the options dialogue?
I do not have this problem with my V15 - luckily I have kept on my PC.
0
Interesting. I don't experience that anomaly; the behavior here is normal.
Do you get these prompts (appropriately localized)?
Select entities:
Entities in set: 1
Select entities:
Specify first point on slicing plane or [Object/Surface/Zaxis/View/XY/YZ/ZX/Line-point/3points] <3points>:0 -
Dear Richard.Thank you for your help.Here a description step by step of my problem:1. Create rectangle2. Extrude vertical3. Command "Slice" and pick cube (1 object in set)4. Select plane "xy"5. Select "Midpoint" of vertical side6. right klick = "Both"Result is a slice within the plane vertical to my viewpoint vectorWhen I rotate the view, the slicing plane stays within the viewpoint vector (although I chose "XY" as slicing plane!!)6a. Result with rotated viewI think there must be a klick to be set in the options dialogue, but I do not find any.Best regardsChristoph0
Have exatly the same problem.
__slice command ignore any BKS inputs
and is unusable since Update to Bricscad 16 !0 -
I think this is a problem that only occurs in the German version. Selecting 'XY' somehow results in selecting 'Ansicht' (View). Maybe using "_XY" instead of "XY" works.0
It seems as this is the solution:_xy for the slicing plan worked as requiredxy delivers a slicing plane vertical to the viewpoint vectorA translation problem within the german version!0
Thank you for conforming this.0
