Getting square footage of cylinder surface or other solids
Is there a way to coax Bricscad (V15 Platinum) into calculating square footage of the outside surface of a cylinder. I know there is a mass properties command but not sure how to use it for this application. Anyone have any ideas?
I am going to assume that you are (still) able to calculate the surface area of a cylinder manually...
For more complex solids: open the Properties Bar and expand the Mass node. -
But the mass properties don't calculate just the outer sheath, the bounding disks on either end are also included. It's an elementary calculation for a cylinder, of course (I was a math major back before they'd invented numbers greater than 42 ;-) but not so much for, say, a complex loft. I can see where it could come in handy for individual faces.
I think it would indeed be an important feature to be able to list properties of single surfaces for quick quantity take-off, e.g. look at what Yorik van Havre has implemented in FreeCAD:
http://freecadweb.org/wiki/index.php?title=Arch_Survey -
As it happens, we are currently working on this...
The properties bar is being extended to also show properties of selected SUBentities, like edges and faces.
...and it will become possible to show a selection of properties at the cursor location by hovering the Quad over entities or subentities.
This is expected to become available begin of next year. -
By accident found out I could use surfaces instead of solids. Created a cylinder surface then use area with sub option entities. The application this is used for is figuring square footage on a pressure vessel (tank) - which from that we calculate how much paint is needed for coverage. I know this is easy enough thru simple math but the figuring square footage of a vessel head surface is a pain, so popping them as surfaces is easier - again using area command but sub options add then pick entities. Thanks to all for the comments!
Howdy, Stranger!
