Moving from Autocad - Main User Interface Customization file not found
Looks like BricsCAD can't find your custom main cui file. have you changed the name of the file or folder recently? Perhaps 'C:\ASOF BRICV14' has been renamed to 'C:\ASOF BRICV16' ?
The fix is in the error message. Run MENU, then browse to the location of your main cui.
Regards,Jason Bourhill
0 -
Hi,
I have a question regarding to this topic.
I also get the same error message.I start BricsCAD using a /P profile.arg file where I define the MAIN.cui file.
Here is how it looks like in my .arg file:"CuiFile"="MYMAINCUFILE"
"MENUNAME"="MYMAINCUIFILE.cui"
"SRCHPATH"=".;%USERPROFILE%\AppData\Roaming\Bricsys\BricsCAD\V16\en_US\Support\;C:\Program Files (x86)\Bricsys\BricsCAD V16 en_US\Support\;C:\Program Files (x86)\Bricsys\BricsCAD V16 en_US\Fonts\;C:\Program Files (x86)\Bricsys\BricsCAD V16 en_US\Help\en_US\"I have that .cui file placed in %appdata% and BricsCAD do load this menu BUT it still displays the error message.
I just click OK on the error message and I can see that my .cui is loaded correctly.I test that by typing in MENUNAME and it gives back the correct path and .cui.
What am I doing wrong? How can I avoid that message box? Is it somewhere in the registry that tells BricsCAD where to look for the file or?
thanks.0
