Geometric tolerances changed from autocad mechanical
 When i open drawings made in autocad mechanical 2000 the geometric tolerances are changed.
For example when a straitghtness is applied in autocad mechanical 2000 it will be translated in bricscad to "u"
What can be done to cahnge this to the "-" straightness symbol?
This happens to all geometric tolerances coming from autocad mechanical.
Johan
